跳转到主内容
加入维修社区 - 创建账户
型号 A1213或A1218,闪存容量:8、16及32GB
half of touchscreen won't respond
I just replaced the glass digitizer because it was cracked. Everything worked just fine but it was hard to see thru the cracks. Now, the upper half of the touchscreen won't respond to touch at all but the bottom does. Any advice would be appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I noticed you never got an answer to this. Are you still having this problem?
完成的
添加一条评论
1个答案
已选择的解决方案
It sounds like you have a poor connection on the digitizer cable, or it is damaged. Try inspecting it for damage, and then disconnect it and reconnect it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 888
