跳转到主内容
这一代一体成型铝机身的Mac mini型号为A1347,包括2010年中期至现在在售的2014晚期型号。
872 个问题 查看全部
Mini won't boot after replacing primary internal HD
This model has the 2 internal drives instead of 1 optical drive. After reassembling (twice) it won't boot. I get a grey progress bar that makes it about half way across the screen before starting over.
Tried to boot into single user mode but no joy. Tried the option key to boot from the 2nd internal drive but no response. I know the second drive ( backup) was fine when I powered it down.
Any help is appreciated, this need to be back at work in the morning.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Of course you formatted the new drive and installed an OS?
完成的
添加一条评论
1个答案
已选择的解决方案
If you haven't already, boot from your original system installation DVD disk, "C" key. Go to the second screen pull down menu to Utilities > Disk Utility. Select the new drive in the left hand column and format it and give it one partition. Quit Utilities and continue with your system installation.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Clinton 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 537
