跳转到主内容
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
55 个问题 查看全部
After driving on LPG, engine cannot run again for a while
I have mazda 626 lx 1998 lpg/gasoline. Initial ignition is always on gasoline and after start I can switch to LPG. Problem started recently when I drive on LPG and off the engine. After that I am not able to run it again for a while. This is usually happened during summer time. Seems to me that need to wait some relay to be opened and gasoline come to the engine. Anyone can help me with advise
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
The original fuel pump relay is located in the relay box which is right next to the battery. The exact location within the box should be printed on the relay box cover.
You should test to see if it operating and sending power to the fuel pump. It is controlled by the Powertrain Control Module but I am not certain how the original gas controls interact with the LPG controls.
BILL
这个答案有帮助吗?
得分 1
1条评论:
There are two relays MAIN RELAY (B5B418811) and Z5A118821 which is relay for fuel pump. I found location of main relay but not sure for the location of relay for fuel pump.
完成的
添加一条评论
添加你的答案
Goran Cabrilo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 447
