跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
Is it possible to replace the non-swappable battery?
I read somewhere that the battery on the new macbook pro (non-retina) is advertised to sustain 1000 charges. After the battery is dead, can I replace the "non-swappable" battery - by myself or via Apple care's services ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, even though Apple puts a label on the battery that says non removable there is only one try-wing screw holding it in place and replacement are relatively easy to find because if has the same battery as the 2011 model. Apple also will replace your battery for (I believe) $200 at the store.
Hope this helps
这个答案有帮助吗?
得分 5
1条评论:
Yes, you're right. Also, I add that, of course, when the Macbook is still on warranty, servicing it at home may void the warranty, so, it's a good advice letting the Genius Bat techies do their job.
完成的
添加一条评论
添加你的答案
desafinado 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,559
