跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
What is the normal fan noise for a MBP?
I had a bit of a spill the other day. Everything is working fine thanks to the tips of the many questions regarding spills here and on other sites.
My question is this: what is the typical noise of a MBP fan. I never really noticed it before, but theres a slight fan hum when the computer is idle that accompanies the spinning hard drive noise. I'm a little paranoid of everything since the spill, so maybe I'm overreacting!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Download iStat Pro here:
http://islayer.com/apps/istatpro/
This is a widget that will run on you dashboard and tell you the stats of your MacBook Pro, including fan speed. I have this on a late 2011 model and the fans are normally around 1000 rpm to 1500 rpm when idling and can go up to 4500 rpm when doing heavy video editing. Tell us what your fan reads under the rpm.
Hope this Helps
这个答案有帮助吗?
得分 0
2条评论:
At idle my fans are around 2000 rpm.
完成的
I just realized that 2000 is the minimum default speed on the 2011 MacBook Pro 15" and mine was lower because it was a 17", which has more internal airflow and bigger fans, and because I have Fan Control set to have a lower fan RPM. You can download Fan Control to a gust the fans on your MacBook Pro if you want. Can you tell me the internal temperatures that iStat is reporting?
完成的
添加一条评论
添加你的答案
Ian Hutchinson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 1,425
