跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
问题已关闭
Can I swap my preinstalled drives?
Hey!
I bought a MacBook Pro 13'' 2012, and I'm coming from a 2009 one.
I want to use my SSD in my new MacBook too.
Can I move my drive directly, or do I have to reinstall OS X and transfer the files?
Are the drivers already included in OS X 10.7.4, or does it download the drivers when running Software Update?
I don't want to restore… :)
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Maybe this is confusing: My question is software related, not hardware!
I am talking about transferring a Samsung SSD 830 from a 2009 13'' MacBook Pro to a 2012 13'' MacBook Pro Non-Retina! The question is just this: Do I need to reinstall OS X (because of the drivers not being included in my current 10.7.4 install), or can I just transfer the drive?
完成的
添加一条评论
2个答案
已选择的解决方案
I tried and - no.
Grey screen with crossed circle.
The Ivy Bridge drivers are not included in the standart 10.7.4 updates, you can wait for 10.7.5 or you'll have to reinstall.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
I swap drives all the time and it always works. When you start up a foreign drive the boot time is a bit longer but you should be alright. I have a bunch of test disks with systems on that i use for troubleshooting and never ran into problems.
这个答案有帮助吗?
得分 1
4条评论:
There hasn't been an update for Lion since the new models came out, so the Ivy Bridge drivers can't be included in my current 10.7.4 version.
I read that the new MacBook Pro non-Retinas come with a special build to include the drivers.
I now that swapping drives usually works, but even if the drivers aren't included? Pretty unsure.
完成的
完成的
oops, sorry - machead is right, of course. The 2012 unit uses a "card" SSD. It's not compatible with standart 2.5" SATA drives.
完成的
I am talking about the 13'' model! Not the Retina model!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 696
