跳转到主内容
广受欢迎的 Apple 迷你桌面电脑,2024款 Mac mini 的维修指南,拆解信息和疑难解答。该机型使用 M4 或 M4 Pro 处理器,最低配有 16GB 统一内存。
How to repair this and what part?
I have broken the clip that attaches to the back of the power button on the Mac mini m4, how to fix this?
Do I replace it with a new power button unit or?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Well you are in luck! Apple now sells their parts directly! Here's the needed part: Power button P/N 923-12072 which you can order from here Apple Self Service Repair and here's the full Apple service manual 2024 Mac Mini manual
这个答案有帮助吗?
得分 1
9条评论:
Thanks for the suggestion, though they don't sell internationally from USA, other third party companies are out of stock, trying to find one online, and the part number I believe is 923-11076, the power button unit, not just the button. thank you for your help though
完成的
@chrisyates66579 - They also do international now! Try ordering, the system will alert you if it can't be shipped.
I gave you the cheaper version on the part, as it looked like the connector was pulled off the button assembly. That's a small circuit board that's screwed on the bottom plate which holds the button as well. Reference Exploded parts view
完成的
@danj ok thank you, yes the connector which is on the circuit board, is that part of the power button part I referenced above
完成的
yeah I can't figure out how to order internationally as well
完成的
@chrisyates66579 - Where do you live? Country and nearest major city.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Chris Yates 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 57
过去 30 天: 57
总计 57
