The Magellan RoadMate 1440 is a portable GPS navigation unit with an LCD color touch screen. It was released in March 2009. It is identifiable by checking the model number listed on the label on the back of the device. It has an SD card slot on the top and a small USB connector on the opposite side. The device is only available in black.
Hi @robertkalfus
What happens when you gently push in the SD card and then release it, does it spring back a bit further than what it was before you pushed it in?
It should spring back just enough for you to use a fingernail to prise it out from the slot i.e. card is no longer flush with the case
由 jayeff 完成的
