跳转到主内容
The RCA 22” DECK215R is a full HDTV with model number M215HW03. Repair of this device requires special, nonconductive tools.
Why won’t the dvd player work
it won’t read the dvd in the slot. It will say no disc
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @makaylabarlow
Can you hear or check if the dvd disc is spinning after it has been inserted?
If you can't hear it, note the position of the label on the disc before inserting it e.g. writing on the label the correct way or upside down etc when looking at the disc being inserted and then after it fails to read, eject the disc and check if the label is still in the same position or not. If it has moved this indicates that the disc has been spinning
If the disc has been spinning, try cleaning the laser lens (examples only) in the disc drive and check if that resolves the problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Makayla Barlow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 10
总计 10
