2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
troun @troun
声誉积分: 1
发帖于: 2012年6月16日
From tear down guide, it seems GPU has no heatsink or cooling system???
Even no trace of thermal paste that could spread heat through lower aluminium case panel...
Any guess?
这是一个好问题吗?
Owen Cunneely @therepairgenius
声誉积分: 7.1千
The Repair Genius
24
29
7
It does have a heatsink. If you look in the pics you can see a black pipe running between the fans that goes over the CPU and GPU. This carries heat to the fans which then circulate it out of the housing.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,263
