跳转到主内容
Repair information for LG ovens, ranges, and stoves.
help with lg orifice sizes
Trying to convert LG stove to LP..... I have many spare orifices that might/should work. LG identifies the orifices by letter and location....EX: for LP, Broiler is "D".
Anyone aware of a list or chart that shows the actual size of LG orifices with the corresponding location letter? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @geezo
What is the model number of the stove?
完成的
LG Stove model lrg3095sw / 00 THANKS JAYEFF!!!!
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @geezo
Here's the service manual
On p.43 of 79 (Sect 5-2 in manual) there a table showing the LP gas orifice code numbers and below that the burner layout diagram. (On p.44 it shows the Natural Gas orifice code numbers)
The complete conversion procedure starts on p.42.
Unfortunately it doesn't specify the actual size of the LP orifices, just their code number
这个答案有帮助吗?
得分 1
2条评论:
Thanks again Jayeff. The doc will be extremely helpful! It shows the btu's for each orifice code, which should/maybe? indicate orifice diameter. Thanks again!!
完成的
@geezo
See if this helps
完成的
添加一条评论
添加你的答案
Geezo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 50
总计 50
