跳转到主内容
Apple 專為可望極致效能專業使用者所打造的產品線。目前, MacBook Pro 產品線包括 13、14、15、16、17 英寸機型,並且大致分為原始非一體成型機身、一體成型機身、視網膜螢幕、觸控列、Apple晶片五個世代。
MacBook Pro 14" replace speaker without disconnecting the battery
Macbook Pro 14" M3 Max left speaker is crackling. I saw in the guide that I have to disconnect trackpad cable and battery cabels etc, so basically the disconnect battery before replacing the speaker.
Can I replace it without disconnecting it? I always use non metalic tools to disconnect cables, so I'm not afraid about shorting something on the logic board during the process(I assume thats why it should be disconnected).
Is there any other reason beside that? I don't want to spend more time on disconnecting it than replacing the speaker if I don't have to :D
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Simple answer - NO!
So you have a loaded gun, would you hand it over to your fourteen year old? Of course not! He may not have the skills on proper handing of the gun.
Why risk the damage you might cause? It doesn't take much to damage things and the damage could be a much more expensive repair!
So back to guns... of course you would remove the magazine and make sure the chamber was also cleared before handing over your gun to your kid. You also use a gun safe to hold it when you didn't have it on your person, as you are ultra careful! As you know kids don't comprehend the dangers of gun. Either hurting you or someone else in your family and that hurt might be permanent.
Shortcuts = Risk
这个答案有帮助吗?
得分 1
1条评论:
Thanks! Then I take my time and will do it properly :)
完成的
添加一条评论
添加你的答案
steve83 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 18
