跳转到主内容
Why is my screen blank
Screen blank and blinking
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
A blank, blinking screen on an HP 700 laptop usually points to a display, RAM, or power-related issue. First, perform a hard reset: disconnect the charger, remove the battery (if removable), hold the power button for 20 seconds, then reconnect and try booting. Check RAM sticks - remove, clean the contacts, and reseat them firmly. Connect the laptop to an external monitor to confirm if the issue is with the internal display. If the external display works, the problem may be with the screen, cable, or GPU. Also, try booting with one RAM stick at a time. If all fails, seek professional diagnosis.
这个答案有帮助吗?
得分 0
添加一条评论
Here are the reasons. Fix these issues.
Pc's display cable is loose or damage
Graphics card issue
BIOS not booting properly
这个答案有帮助吗?
得分 0
添加一条评论
@kelvinmacharia ,
You say "blinking" what is blinking? Do you mean the LEDs are flashing? It may also Beep at you in patterns... If so, they are error codes and you can look them up on the following link (HP Support).
Click the (+) plus sign in a circle in front of "Identify the notebook light or beep code" look at the codes for one OR more that match what you're seeing...
...again click the (+) by those and read the meaning and actions you can take.
Follow the instructions that match your error code(s).
If, after you do that (or if blinking DOESN'T mean the LEDs) it still has a problem, come back and tell us what you found, what you tried already and what IS blinking, a video and photos can be helpful. And someone will be able to guide you better...
Good Luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelvin Macharia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 27
