跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Why don't my internal Mic and speaker don't work anymore?
I had to open my iPhone because it was dusty between the glas and the display. by following he guidelines everything worked out fine. But unfortunately now the integreted mic. and the speaker don't work anymore. Loudspeaker and Headset with mic are working fine.
Please advise
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
You had your device listed as an iPhone 6G. There is no such thing as this. Can you tell us what model your iPhone is?
完成的
oops. it's a iPhone 3G of course.
完成的
添加一条评论
2个答案
最有帮助的答案
Make sure ribbon number 4 is connected. Disconnect and then reconnect. You can look in the tutorials to see where number 4 is if you dont know or if its not labeled.
这个答案有帮助吗?
得分 1
添加一条评论
Sounds like a pinched/damaged or not fully connected at one or both ends.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andreas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,435
