跳转到主内容
这台13寸的MacBook Pro使用四核英特尔十代i5/i7处理器和锐炬Plus核芯显卡,于2020年5月发布(型号为A2251/EMC3348,拥有4个雷雳3接口)
Half of the keyboard lighting not working after disassembly
I replaced thermal paste on my 2020 Macbook Pro A2251. Everything seems to work fine except half of the keyboard lighting. I suspect I didn't connect the cable properly but unable to find which exactly cable. I can't find a disassembly guide for this particular model anywhere and guides for older models didn't help.
Update: Added a picture
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Check near both the fans, I think there are 2 connections for the BL
完成的
Thank you very much! I'll try to reconnect this cable. Do I have to disconnect the battery just for this?
完成的
@ray68836 It is always recommended to disconnect the battery before any internal adjustments are made ;)
完成的
@livfe Thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
I am not 100% but check the connections by the fans I have marked, 2 of them should be for the BL
@danj to assist further if I got it wrong.
这个答案有帮助吗?
得分 0
8条评论:
Thanks, but mine looks totally different. I attached a picture to my original post.
完成的
@ray68836 Oh I took my image from the device listed guide! Edited the answer.
完成的
There must be a mistake. Mine is 100% A2251.
完成的
@ray68836 I edited the answer and marked the connections to check.
完成的
@livfe Thanks a lot for all your help! The longer cables (top of the image) are most likely from the fans as the fan replacement pictures for this model have them which means I need to check only the other two cables.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Ray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 50
总计 50
