跳转到主内容
The Xtreme 2 is a large portable Bluetooth speaker, released in January 2018. This Speaker comes with an IPX7 and up to 15 hour battery life. Model: PL
Power button only works sporadically when on battery
I have a JBL Xtreme 2 music speaker where the on/off button only works sporadically for turning it on.
When it finally is turned on the button always (as in 100% if the time) works when turning it off.
If the speaker is plugged into an outlet using the charger the button instantly turns on the speaker.
So to recap: When wanting to turn the speaker on when it runs on battery, the button only works sporadically - as in I have to pres the button 3 to 10 times before it turns on. The button works 100% of the time for turning it off or for turning it on, when it is plugged in via the charger.
Once the speaker is turned on the battery can keep it playing for hours and hours... So I do not see this as a battery issue.
The speaker has always been used in our bathroom sitting on top of a closet furthest away from the shower, so it has been exposed to some moisture.
Any suggestions as to what the cause could be?
ChatGPT suggested a slightly corroded connection on the power on button - but would love to hear from people here as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This can be cold solder joints. If you were using the speaker in bathroom I recommend to check that solder points and maybe put on a new tin with flux. This could help.
这个答案有帮助吗?
得分 0
1条评论:
Thanks Jakub. Yes, makes sense.
I just tried disassembling it - and had to give up. Was worried I would mess something up. No easy access to get a good look at the cable for the on/off button.
I used a Youtube video as inspiration for disassembling it - but apparently my model has had glue added, so the speakers can't be removed even when all screws are removed.
If anyone has done something like this for the Xtreme 2 before, I am all ears.
完成的
添加一条评论
添加你的答案
Esben Rasmussen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 22
总计 22
