跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
My I iPhone use to reset sometimes
My iPhone use to restart sometimes
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your iPhone restarting on its own is likely due to a damaged sensor. There are many parts the phone checks for every few minutes and if they do not respond the phone restarts in an attempt to get the sensor to respond. Most commonly on your model it is a bad barometric sensor on the charging port flex cable. There are other possibilities as well. You can look for a panic log in the analytics section of the settings. If as panic log is present the info there can help you to narrow down the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zaid Abubakar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 17
