跳转到主内容
Repair and troubleshooting information for the HP 250 G7, an HP laptop part of the HP 200 series. Released in December 2018.
Why is my pc turning on?
While turning on the PC, the system displays the message Diagnosing your PC followed by Repairing disk errors. This might take over an hour to complete. However the system does not start up afterward.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This likely indicates a damaged drive or corrupted SSD. Similarly, maybe windows or your BIOS/firmware got corrupted. Does this happen instantly? Or does it take a moment to try and load Windows first?
这个答案有帮助吗?
得分 1
添加一条评论
If is telling you it is trying to fix the drive, that is your answer. The BIOS is doing its job. Can the drive be fixed -- maybe.
But, it will have to be removed and fixed on another system. You may however be able to fix it booting up on a Linux USB.
The first thing you need to do is to copy off all your stuff if you can get access to it. If the system won't recognize it or see anything on it, then there isn't many options to recover your things.
A full format may fix the problem. Then you will have to reinstall the OS and all your programs. However, I wouldn't advise trusting that it won't fail again in the near future.
The easiest thing is to just replace it and start over. If it is an HDD, it would be a good time to upgrade to an SSD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hassaan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 36
