跳转到主内容
The Kindle Paperwhite 12th Generation was released in October 2024. It can be identified by model number SA568B. This model features a 6.8-inch E Ink display, a USB-C charging port and 16gb of storage and its available in three colors: Black, Raspberry, and Jade.
Magnetic Casing Causing the Unit to Not Stay On
I've followed every step in the Amazon playlist (Outside of opening it up) and nothing is working to get this kindle to turn on and stay on. It will power up for half a second then fall asleep. The battery seems fine from the outside. We did have a magnetic case on it and I'm worried that somehow has messed it up. When I do the hard reset it will even go through the whole boot system (30 seconds plus) but then once it's loaded it turns off. That's why my guess is that it's something to do with the magnetic case. Obviously I removed that but I'm about to open it up and see if there is any visible issues. What exactly should I be looking for?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I'm experiencing the same issue using the official Amazon Kindle magnetic case. It can restart but I can't access the system; it's stuck on the lock screen for a week now and I still can't resolve the problem.
完成的
添加一条评论
1个答案
If your Kindle powers on for a few seconds and then shuts off, the issue is likely with the magnetic sleep sensor. Magnetic cases can trigger or even damage this sensor, causing the device to think the cover is closed and forcing it to sleep. Remove the case, move it away from the Kindle, and hold the power button for about 40 seconds to do a full reset. If it only stays on while charging, it’s probably not the battery but the sensor. If you open it up, check for loose connections, corrosion, or damage near the magnetic sensor or battery cable. Avoid using strong magnetic cases in the future, as they can interfere with the Kindle’s sleep function.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Caleb Martens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 30
总计 77
