跳转到主内容
First generation, based on the Ford C1 global platform.
Hazard lights turn on and off randomly
The hazard light keep turning on and off randomly
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First thing to do is try to pin down where the problem is coming from. Since the only part you can really get to is the switch itself, I'd try disconnecting the switch to see if the problem goes away. You can also follow the service manual test procedure for the switch to see if it's working correctly.
Mazda 3 Service Manual - Hazard Warning Switch Inspection - Exterior
Try those suggestions then come on back and let us know what you found. Good or bad, your experience could help the next person who comes along with the same problem.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Patrick Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 25
