跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Why won't my iPod work?
I had replaced the battery cause it was old. Since then the iPod doesn't charge at the computer but turns when plugged into the wall. Message says to connect to a computer to resolve issue. But it won't turn on when plugged into the computer. I had changed the motherboard. Same issue. What else could it be? i swapped everything i could think of that would affect the power and no dice.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Hi,
the battery to low message sounds to me like a bad hard drive.
这个答案有帮助吗?
得分 0
添加一条评论
Did you already try to use a different cable, maybe yours is damaged?
这个答案有帮助吗?
得分 0
添加一条评论
As asked by Crisb try a different iPod chord. If that doesn’t work try hooking it to a friend’s pc. If it works then you may have a USB problem. Are you using Mac or windows?
这个答案有帮助吗?
得分 0
1条评论:
I have multiple cords and i have a pc i tried it on as well. just sits and doesn't take enough charge to be recognized by the computer. It has the "battery too low" and that's as far as i get. I'm starting to think maybe the hard drive or the battery is shot again...
完成的
添加一条评论
添加你的答案
martyz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 639
