跳转到主内容
The Craftsman Pressure Washer 580.752352 is a gasoline-powered cleaning device that utilizes a 190cc engine to generate 6.0 horsepower and deliver a maximum pressure of 2500 PSI. This page provides detailed information and repair guidance for this model, which features a 30-foot high-pressure hose, multiple nozzles, and is mounted on a portable steel frame with 10-inch tires.
Does the pump itself need to be maintained with oil changes?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @markbaldan
The owner manual states that the engine oil needs to be changed after every 50 hours of operation or yearly whichever is applicable. (see p.17 of the manual)
Regarding the pump it only mentions that to protect the pump from mineral damage or freezing temperatures is to use a lubricant known as a pump saver. (B&S part number 6039 - see p.22 of the manual (examples only)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mark Baldan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 29
