跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
iMac 27” mid 2011 EMC2429 won’t turn on
I got an Imac 27” mid 2011 EMC2429 which was not turning on. No chime, no fan working, Nothung.
First I thought it is PSU. I tried my PSU on another Imac it works fine. On my Imac I tried another working PSU same result not turning on.
Then I have noticed that when I plug it in, Led 1 on motherboard blinks for a second. Anybody could help me what can be broken, How to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Did you take the logic board out and refreshed the thermal paste on the CPU?
完成的
Yes, it is completely fresh
完成的
添加一条评论
1个答案
Then I’m suspecting you didn’t seat the CPU chip cleanly into the socket, often the pins get bent. This system is hard to mount the heat sink springs and the chip.
You’ll need to pull the CPU out and check the socket pins. Be careful as bending them back can snap them. You’ll want to soften the spring a bit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tural Huseynov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 38
