跳转到主内容
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
My touchpad dn,t recharging when I conect it
what i have to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
5个答案
最有帮助的答案
There are known issues with the USB connectors. Try wiggling them around when you plug in the charger cord.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem, I discovered that I had a short in my USB Cable ....I bought a new mini-USB cable and connected it to the wall charger and the TouchPad and I was good to Go.
-Steve Nolan Schenectady NY
这个答案有帮助吗?
得分 0
添加一条评论
If you have a Kindle, the cable will charge your TouchPad until you can purchase a replacement cable. I purchased a new cable from the internet for around $3 and free shipping.
wsb/Iowa
这个答案有帮助吗?
得分 0
添加一条评论
This problem is well documented on hp discussion boeards. The problem with it not charging can be bad cable, bad male connection on the touchpad, or bad battery. After tryinall ticks to hold combo buons for 60 seconds and purchasin new chargr ulit direct from HP, my last option is trying the battery. I will keep you posted. It is just out of warrantee and HP wants close to $400 to repair. I asked them about a possible recall and communication went silent.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same charging problem. After buying the converter online (OK, I bought it twice, but don't tell anybody) it turned out to be the USB cable. I was able to get one just like it at the local Goodwill for a dollar : )
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
benedic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 2,404
