跳转到主内容
Nintendo Switch Joy-Con 控制器的维修指南和信息。
Stripped screw and its removal
Do you think this screw can be removed by using the extractor tool set or should I just go for the drill solution? I've tried rubber band before and it didn't work and I really need to get into the joycon to fix my drift and lock mechanism. Thanks for the answers!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
IV had the same problems with the 3tri screws I used a tiny small metal drill bit like for a Dremel tool and then used a small easy out bit it turns and bits into the striped screws hole it'll remove it nicely hope it helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
soap 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 31
