跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
Whirlpool WTW5057LW0, F5E1 error code
Whirlpool WTW5057LW0 washer with error code F5E1 - lid switch. I replaced the lid switched and reset the washer (unplugged for about 10 mins). Pushed the arrow button a few seconds, 4 lights illuminated to start a cycle, NOTHING. No clicks to the door lock.... nothing. I tried several things, different cycle, nothing. I ran diagnostics, no codes. IDEAS???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @orlandotsosie
Don't know the washer but it seems that the lid switch is part of the lid lock assembly. The assembly consists of the lock, the lock switch and the lid switch.
Here's the tech sheet for the model that may help.
Disconnect the power to the washer and then check if the lid lock assembly tests OK as per the lid lock resistance chart at the bottom of p.2 in the sheet when testing from the relevant control board connectors
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Orlando Tsosie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 56
