跳转到主内容
The Dell Precision 5560 was released in November of 2021 and identified by the model number 5560.
stripped screw and I dont have power tools. (dell precision 5560)
so lately i have noticed that the screws get loose and literally fall off my laptop. figured i could just screw it back in but i only had flathead screwdrivers. i had to work with that. specifically only two screws kept falling and at this point its 5 to 6 times. so i figured ill just buy some new screws and remove all the old screws and put in the new one. but i could only manage to get 6 out and two were very stripped and screwed in very tightly (completely unrelated 2 screws compared to the one i talked before.) now the old screws were starheads and i bought new screwdrivers to take them out but i cant seem to remove these two. i tried the rubber band method and many more. at this point only three options are creating a mold and making a screwdriver for those screws, using wd-40 to loosen them and using powertools to make it flathead. but i dont wanna destroy the gorgeous aluminium back plate and i also dont have power tools. is there any other way to remove it? if so please do tell me. and also the spaces for them are very tight. i dont have a phone so i dont know how to show you guys but you can search it up online (ik im askin too much).
thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
so, i tried using wd-40 which absolutely did nothing. the i did as david greene said that also dindnt work. so any other recommendations?
完成的
添加一条评论
1个答案
If the screws aren't stripped to the extreme, then try pushing a bit harder and/or using the proper screwdriver to get them out (but making sure not to strip them further). Screws rarely get that stripped unless someone used the wrong tool (usually a size too small). The screws may have Loctite blue or a similar screw fix tightener chemical holding them more strongly than jus the threads alone would. That can make them a bit harder to undo, but only the first time, as after the chemical has dried, it only works once before first removal.
Using oil is probably not a good idea unless you can exert extreme control over its flow/quantity/direction. If it gets on any of the PCBs or components, it could cause big trouble.
If all else fails, sometimes it works to use a slot driver inside the area that hasn't been stripped. Using it a slight angle will often loosen the screw.
Please keep us posted.
这个答案有帮助吗?
得分 0
1条评论:
my screw was originally a strahead. now it has turned into an internal hex screw. but the screws i have for that is too small. i dont know what to do at this point
完成的
添加一条评论
添加你的答案
rabahh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 53
