跳转到主内容
加入维修社区 - 创建账户
ThinkCentre M73(型号 10AX、10AY)“Tiny 小机箱”台式机,生产于 2013-2017 年左右。
System error when turned on
My pc shows an error message when turned on about product patents, client Mac address.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
cpu fan failure
由完成的 分享
添加一条评论
1个答案
  • BIOS/UEFI configuration issue
    • If the system can’t find a valid boot drive, it tries to boot over the network (PXE boot). That’s when you see Client MAC address and patent/product messages.
  • Missing/Corrupted DMI (Desktop Management Interface) info
    • Sometimes after a motherboard replacement or BIOS reset, system-specific info (like product number, serial number, etc.) isn’t written to the BIOS properly. HP, Dell, and Lenovo systems often throw “Product Information Not Valid” errors in that case.
  • Hard Drive / Boot Device issue
    • If your storage drive isn’t detected or has failed, the PC skips to network boot.
How to Fix-
  1. Check Boot Order
    • Enter BIOS/UEFI (usually press F2, F10, ESC, or DEL at startup).
    • Ensure your hard drive/SSD is listed as the first boot device, not “Network Boot” or PXE.
  2. Reconnect Storage Drive
    • Power off the PC, reseat the HDD/SSD cables (or NVMe drive) to ensure it’s properly connected.
  3. Reset BIOS
    • In BIOS, look for “Load Optimized Defaults” or “Reset to Defaults” and save.
  4. Check for DMI/Serial Info
    • If the error mentions product patents or product info not valid, it may require reprogramming the system board information (usually only a service center or manufacturer tool can do this).
  5. Disable PXE Boot
    • If you don’t use network booting, disable PXE/Network Boot from BIOS.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gaone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 29
总计 280
