跳转到主内容
Xiaomi Redmi Note 11 4G Released 2021, December 01 181g, 8.9mm thickness Android 11, MIUI 12.5 128GB storage, microSDXC
How can I fix my charging port
My phone isn't charging how can I fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Being Tony Stark, I'm sure you've tried the usual; different charger, new cable, cleaning the port and checking it for damage.
Given all that didn't help, the next step is usually to change the charging port. Your phone is similar to many Android phones in that the charging port is mounted on a small auxiliary, or daughter, board that is fairly easy to replace. Sorry to say iFixit doesn't have a guide to that repair, but the Spanish site Nadie Me Llama Gallina has just what you need; step by step instructions on replacing the daughter card.
Manuals / Xiaomi Redmi Note 11 / Auxiliary Board - Nobody Calls Me Chicken
The daughter card is readily available on a variety of sites such as Amazon, eBay and AliExpress, among others. An internet search for your phone's model plus "charging port replacement" will show you several options; pick one that suits your price and availability needs.
这个答案有帮助吗?
得分 1
添加一条评论
Hi @tonystark40323
Have you tried using a different, known working, compatible charger or charger cable to check if the charge port may be problem?
If so try replacing the charge port board in the phone and check if that resolves the problem.
Here's a video that shows what to do.
Search online for 560001K7TN00 5600020K7T00 to find suppliers that suit you best. (examples only)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tony Stark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 58
