跳转到主内容
Repair and disassembly information for Google's Pixel 8a Pro smartphone, released on May 14, 2024. Identifiable by model numbers GKV4X (5G Sub 6GHz) and G8HHN (5G mmWave + Sub 6GHz).
Is there any replacement for the flashlight module?
I have a broken flashlight, the part with the light on it snapped off from the cable.
I was looking for that part alone, but I don't see it, does it come in any group of parts?
If there's any way to get it, I was wondering if there is also a guide to replace it or if it's not possible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
On gear tear, there is a replacement (I can't access the website at school, so I would check the compatibility). To install it there is a guide on the IFIXIT website to replace the 8a flash adhesive (you will want to get a new one of those too).
这个答案有帮助吗?
得分 0
2条评论:
Are you sure it's available? I've taken a look over there, but there's only modules for other Pixel models.
About the guide, the adhesive replacement doesn't cover the full module removal and installing a new one.
完成的
I am not completely sure. When I get home from school, I can check to website on a non-blocked computer. For the guide, the following link might be a help to you. For me its at least better than nothing. Google Pixel 8a Rear Cameras (Wide and Ultra-Wide) Replacement
完成的
添加一条评论
添加你的答案
Shy Frog 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 49
