跳转到主内容
Repair guides, service help, and troubleshooting information regarding Hitachi refrigeration units.
Condesner Location on Hitchani Refrigerator
Hi,
Can anyone guide me on where the condenser location is on the Hitachi R-T380ES1KV refrigerator? I have checked at the bottom, in the compressor compartment, but it's not there.
It is also not mentioend in the service manual. Any had an experiecne about it?
Thanks in advance.
Regards
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @mohsins
Not sure regarding the model you posted but in some Hitachi refrigerators they have what is called "heat radiation pipes", either at the back or on the sides, on the inside of the cabinet walls.
When the compressor is running, check if the back or a side wall feels warm or even hot. If it does then most likely that's the system they're using to release the heat from the sealed system and not a condenser coil or unit. Basically, not meant to be removed.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your time and guidance.
完成的
添加一条评论
添加你的答案
Mohsin.S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 36
