跳转到主内容
Model A1046 or A1095 / 1280x854 screen resolution
118 个问题 查看全部
Can't turn it on, screen stay at apple logo then stop
My PowerBook G4 just can't turn it on, it stop loading when the apple logo appear. i turn it off by holding down the button. Tried to turn it on again with a OS disc but didn't work n the disc couldn't be eject..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Er...i had try what lemerise said, it didn't work.
And i did the repair 2 times, after all repairmen still remain the same. But now go in to a new page that is a "stop sign" instead of the apple logo.
Tried to press the power button and hold down the Option key. its goes into a page with a flashing "earth" logo for 5 seconds then "ox9" logo another 5 seconds, the "stop" sign is at the end.
i have no back up for my laptop, should i do the "Archive & Install"? its the first time of fail to boot it up in 54 months, hopefully it will work again!
完成的
The "No" sign means that it cannot startup from the current disk, the filesystem is probably corrupt. your best bet is to reinstall the OS.
完成的
添加一条评论
4个答案
已选择的解决方案
Try this:
1- start the PB holding down the 2 keys ->command->s
hold the keys until you seen a black screen with with letters
2- type: fsck -fy (there's a space between k and -
3- wait, the computer will scan the hard drive searching for errors.
4- when you get the text: <<The volume "hard disk name" appears to be OK
5- type: reboot
Redo #2 until you get the text in #4
这个答案有帮助吗?
得分 2
添加一条评论
In case what lemerise said to do will not work, then first try repairing the system or reinstall the system. Insert the System installation disk and start up holding down the "C" key. On the third screen the pull down menu will appear. Go to Utilities and pull down to Disk Utility. Run the repair. If this fails then do the system reinstall and download and install your software updates
这个答案有帮助吗?
得分 2
1条评论:
I would recommend the "Archive And Install" option if a reinstallation is nessicary, since all data and programs will be preserved in a folder, in the new system.
完成的
添加一条评论
it stuck on the start and won't move the blue stream light is on
这个答案有帮助吗?
得分 0
添加一条评论
How do I get the disc drive to pop out if I can't get my powermac G4 to boot up? Only the apple icon stays on grey screen... the keyboard key for opening the disc drive won't open it. Any other trick?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 2,903
