跳转到主内容
3rd Generation high performance tablet computer released by Apple in October 2018. Models A1876, A2014, and A1895.
Stuck in recovery mode and fails to recover
I purchased an ipad pro 3rd gen that I was told had been factory reset during an update which put it into recovery mode. I attempted to to fix it by using itunes with different cables and different devices as well as took it to 2 different repair stores. All have said they don't know what's wrong with it. I started to use 3UTools to try force loading older updates thinking that the issue was i wasn't trying to restore and update it to the same one that caused the restore mode. This however still did not work, it continues to fail around the same point however, when it says "AMRestorePerformRestoreModeRestoreWithError" when it is attempting to restore the nand chip. I'm at the point where I just want to replace the chip but I don't know where to get one or how to replace it. Can anyone help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
have you tried to to recover in dfu mode
这个答案有帮助吗?
得分 0
添加一条评论
yeah it sounds like the NAND flash failed on it. when that happens though, I would personally just replace the device.
unless you have a bunch of specialty equipment and years of micro-soldering expertise, you are not going to be able to fix it. most repair stores that do micro-soldering even will probably not be able to fix that, its a very difficult/specialized repair that only some places do because you need to program/flash the new NAND chip. if you can, maybe try to return it, or sell it as is as a parts ipad/donor parts ipad to recoup some of the money.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
3309theCommander 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 74
