跳转到主内容
The AT&T Trimline 210M is a corded phone with a lighted keypad and 3 one touch memory buttons. Available in white and black.
How can I set the one touch dialing?
I followed the manual but my phone doesn't seen to accept my one touch or memory entries.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @jenniferrehder
Just confirming that you tried the method shown in the image below and it doesn't store the number on any one of the 3 "emergency symbol buttons" on the phone, and also none of the speed dialing numbers are saved as well, is this correct?
Are you doing this with the phone plugged into the telephone line socket?
(click on image)
这个答案有帮助吗?
得分 1
3条评论:
Yes, I tried it by the book and nothing seems to happen. It's a brand new phone. It is plugged into my Mediacom modem since the house doesn't have the old time wall phone jacks. Thanks
完成的
@jenniferrehder
Is the phone service working i.e. can you hear the dialing tone when to go to make a call?
If there's no dial tone, just confirming that the Mediacom modem has a dedicated port for a phone service (which the phone is plugged into) and not just Ethernet ports for computer and TV etc internet connections?
If you can make and receive calls OK, return the phone to where you purchased it and get a refund or a replacement as it is faulty.
The phone requires power for the memory to be retained and the only way it gets this is from the phone line - be it provided by a modem or a cable in from the street.
完成的
Thanks so much, yes the phone works to call out and receive calls. So perhaps the memory function is just not working.
完成的
添加一条评论
添加你的答案
Jennifer Rehder 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 56
