跳转到主内容
Repair, disassembly, and troubleshooting information for the Geek Bar Pulse vape.
I stuck q tip in the mouth piece
Trying to remove dirt i stuck a q tip in the mouth piece after this it taste burnt and wudnt pull at all
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The mouthpiece is only snapped in place. You can remove it by grasping it with a pair of pliers and twisting it hard to the side. Once you have it off you should be able to clear any dirt or obstructions in it.
When you go to replace it, pay attention to which way it goes. One side has two horizontal tabs, while the other side has a vertical alignment line, so you have to match up that line with the correct side. It may be hard to push back in place, but brute force will eventually get it reseated. The housing seems to be pretty sturdy so don't worry about breaking it.
This video shows how to open it up (and refill it if you're interested in that aspect).
GEEK BAR vapejuice refill hack - YouTube
这个答案有帮助吗?
得分 1
添加一条评论
You probably pushed one of the components down into the tank to far. Best solution would be to open it up same pull it back into alignment. You could try with some fine point tweezers, but will likely still have to open it up. There's a guide for disassembly on here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dayna Carmack 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 33
过去 30 天: 115
总计 233
