跳转到主内容
The 2013 revamp of the desktop Mac series known as the Mac Pro.
Fan - Mac Pro A1481 (Late 2013) pinout
Hello everyone,
This may be a strange question -
does anyone know what the connection for a 4-pin PWM cable for this fan looks like?
I would like to use it in my project, and it must be connected to a standard USB PWM controller.
Thank you in advance for your help and suggestions.
Regards,
Tom
I rushed to find a solution for the overheating MP6.1. I have the impression that OCLP, in combination with newer versions of OSX, which are more demanding in terms of system resources (RAM, CPU, etc.), cause older computers to work harder. I started looking for a solution and, using 3D and an additional original fan from the MP6.1, I achieved quite satisfactory results without the noise of an F-35 taking off. To improve airflow, I removed the original bottom cover, and the second fan is powered by a cheap 4-pin PWM controller. I soldered the cables into the fan's test pins and added a PVC mesh filter between the two original MP 6.1 fan diffusers.. At the moment, such a fan can be bought in the UK for £19, which is quite reasonable. If necessary, I also run TG pro on low settings so as not to drown out my thoughts :) I think that the whole thing doesn't look particularly awful and is quite compact compared to other designs 🤔
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
From the left:
Yellow,
Green,
Blue,
Black
It works brilliantly and efficiently.
完成的
添加一条评论
1个答案
已选择的解决方案
This fan is connected by a ribbon cable via the clinch type connector your Red circle crosses over. The circle pads are test pads not intended for use. As to figure out which pins of the connector does what will require reviewing the schematics and board view drawings.
这个答案有帮助吗?
得分 2
6条评论:
Thanks :) Even as test pins, they provide voltage and RPM. Problem solved, and I finally finished the cooling project for the Late 2013 Mac Pro :)
完成的
Hi Tom. Very nice solution to improve the air intake of your Mac Pro.
As many others interested, would be nice to have the print instructions for the stand. Thank you in advance, cheers!
完成的
@ernestcrus - I have the same system and have not encountered issues as Tom has expressed. I have run the system quite hard running OpenCore and macOS Ventura 10.13.x processing ultra large images and creating some video's as well. The newest M Series system are clearly better than this old tank which I still love. I'm waiting a bit more before I jump.
完成的
Hi Dan. These old trashcans suffer from internal overcrowded design, just because they have only one fan which is on the top. The same E5-1680 V2 cpu was running idle in my Sabertooth X79 default @ 23-27 centigrade, but in this trashcan around 50. What Tom did is impressive and would give these trashcan a chance. Cheers for pointing out solder points.
完成的
@ernestcrus - Not really! Clearly a small fan is not as efficient as a larger one! But design on how the air flows also needs to be under stood. You wouldn't stand in front of a room fan expecting it to dry your air as effectively as a hair dryer held in your hand and yet the hair dryer by design is more effective than the largest room fan.
So back to the mystical small fan in this system, it's very effective in cooling more so than a standard PC case design. It's perfect for its design!
Now with that said it was limited for sure! As each newer generation of Intel & AMD chips required more cooling than this design could offer so it couldn't be expanded with newer generations of chips!
But... if one could fit a M3 Ultra chip or two into this case it would purr! Not exceeding its cooling design! Of course that's very wishful or is it? The Mac Studio is the 2013 Trash Can reincarnated!
FYI it has a smaller fan with a flat heatsink design, no need for GPU heatsinks! Making it simpler.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 104
