跳转到主内容
How to fix PS4 dualshock controller right joystick stick drift
The right stick when pressed down just moves the camera up when pressed to slide in a game like Fortnite and when aiming it's not stable and moves by itself in any direction so I constantly have to pull it back to track a player in a game
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The Dualshock 4 controller uses potentiometers for sensing joystick positions. Since these are mechanical sensors, they wear down over time, usually within a year or two depending on usage.
Sometimes you're lucky and there's just some dust inside the potentiometer that you can remove with a blower, most more often than not you will have to purchase either a replacement joystick assembly, or new potentiometers, and perform some soldering in order to fix stick drift on these controllers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tshepang 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 28
总计 103
