跳转到主内容
加入维修社区 - 创建账户
Originally internally coded as LFA, the 2015 Sonata was unveiled in Korea late March 2014, and was unveiled in America at the 2014 New York International Auto Show.
Seat belt not retracting
After driving, and unbuckled, the seat belt is not retracting into the recess between the doors
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I've run into that sort of situation a couple of times now. In the first case it was because the belt got twisted while retracting and the extra bulk caused by the twist jammed up the mechanism so it didn't work any more. In that case I ended up taking the trim panel over the seat belt mechanism off and managed to work the belt out far enough to free the twist. After that, it was just a matter of letting it retract normally, then replacing the trim and it was fine.
In the second case I encountered I wasn't so lucky. A piece inside the belt mechanism had broken and I ended up replacing the entire seat belt.
Hopefully it's just a twisted belt, but in ether case you'll need to pull the trim panel of the seat belt along the pillar and examine the mechanism to figure out what's wrong. If it's a twist it'll be obvious.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TDK 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 101
