跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Removing digitizer glue residue
I have an iPad2 on which the digitizer was completely shattered and had to be removed piece by piece. I've done this but there is a lot of glue residue left all around the edge of the device. I have the 3M glue pads and I'm ready to install the new digitizer, but I want to remove all the old glue first, some of which still has somevery fine glass shards stuck to it. Is there a solvent I can use to achive this without damaging the device? If not, is there a way to do this so that I've got a clean surface to apply the new glue pads to?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
12个答案
已选择的解决方案
You can use a spudger (metal or plastic) to scrape it off. A putty knife, or any flat scraping utensil will work also. Just go slowly and work it bit by bit. The glue will ball up and can be peeled off. If you want to loosen it some, take a hairdryer and heat up the glue. That will get it to soften and release. Just be careful to avoid blowing heat directly onto the LCD, stick to the edges.
这个答案有帮助吗?
得分 0
1条评论:
Try some hand sanitizer with a soft cleaning cloth.
完成的
添加一条评论
最有帮助的答案
CHARCOAL LIGHTER FLUID
Not sure if this will work for iPads but I use it for laptop digitizer bezels and it works for me.
Pour some lighter fluid into a small glass. Not much, just enough to dip a Q-tip.
Dip the Q-tip into the fluid and gently coat the adhesive and let it soak in for a few minutes.
Use the dipped Q-tip to remove the adhesive using a forward pushing motion as if you are shoveling or chiseling it off. It softens the adhesive to a point which it won't stick to your fingers and leaves no residue. There may be an oily feel and doesn't smell too great but it works pretty good actually.
After completely removing the adhesive, I go back around the bezel and clean with rubbing alcohol to remove and residual finger prints, adhesive debris, etc.
Oh and I don't recommend smoking while handling the lighter fluid and would recommend not using it around any electrical sources or batteries, etc.
这个答案有帮助吗?
得分 2
添加一条评论
When it comes to removing the excess adhesive that I see when doing a repair on phones or tablets I normally have used Goof Off FG661. From my experiences it removes the adhesive extremely well.
Materials: Goof Off FG661, Bottle cap, pack of Q tips , and some paper towels just in case.
The way I proceed is poring a few of the liquid in a bottle cap or something similar as needed. Grab a Q tip and dip it into the FG661 then run the tip of the Q tip over the adhesive that you are trying to remove (Try not to over saturate so it does not run into other parts). Then with a Nylon Plastic Opening tool or something that you can scrap with go thoroughly removing all the adhesive. Continue the process through out every part that has the adhesive you are trying to remove.
This method has worked perfectly for me without any issues in adhesive removal.
这个答案有帮助吗?
得分 2
添加一条评论
Goo gone and rubbing alcohol work great
这个答案有帮助吗?
得分 1
添加一条评论
se a pencil eraser, I am using one I had lying around. The one that worked best is white, branded: Staedtler Mars Plastic and Made in Germany, part number 526 50. It says on its side: “Made for pencil and film” Did that after rubbing the rough goo off with a credit card. Then pencil eraser, and intermittently credit card & rubbing alcohol. Tedious but eraser is crucial. Other erasers worked but not as well as the white Staedtler.
这个答案有帮助吗?
得分 1
1条评论:
....that's a genius idea!
完成的
添加一条评论
I use 99% alcohol to clean the housing.
这个答案有帮助吗?
得分 0
添加一条评论
hi, i have an ipad mini2 my screen is broken i try to change my screen i have remove the broken screen and there is some glue still stick on it. i used the 409 and window cleaner still didn't come out. what should i use to remove it?
这个答案有帮助吗?
得分 0
添加一条评论
Tried 80% alcohol (windshield wiper), which had zero impact. Also tried hydrogen peroxide 3% (for cleaning wounds) just in case that works, also no impact. Acetone ultra strong nail polish remover also zero impact.
Scraping with nails seems to work best of these things, but doesn't really work. Yet to try 99% alcohol :).
Update (03/22/2017)
At the moment I used acetone and then scraped, followed by using some oil to clean it a bit more - stuff we had in the house. Still not good, but almost OK.
这个答案有帮助吗?
得分 0
2条评论:
Try goo gone its for removing residue and glues.
完成的
Anyone reading this, DONT use nail polish remover, it usually contains acetone which dissolves some types of plastics!
完成的
添加一条评论
What if you are only replacing the screen, and need to salvage the OEM digitizer? Most of the adhesive peeled off, but there is still a lot of adhesive left on the digitizer. How would you get it off without scratching the color off of the digitizer?
这个答案有帮助吗?
得分 0
1条评论:
I have the same exact question as u and cant find the answer! All other answers are for the front glass screen on the phone. I cant ruin my inside lcd digitizer with scraping or the wrong liquid but i gotta get all this glue off! What did u end up doing?
完成的
添加一条评论
morpheousman01
这个答案有帮助吗?
得分 0
添加一条评论
I found that paint thinner on a Q-Tip made the built up glue soft and easier to scrape off using the small flat blade screw diver that came with my new battery and touch screen, but it wasn’t safe to use on the plastic parts, only the aluminium. So, being a mechanic, I tried using several cleaners that we use in automotives. CRC CO Contact Cleaner worked just as well at softening the old tape and glue as paint thinner, but is safe on plastics. I sprayed some into a cup and used a bunch of Q-Tips, and it worked well but the contact cleaner evaporated too quickly. I then found something that works super. It is called Perfects Contact Cleaner, and it is designed to work in the Tropics where I live. While dissolving the glue, it also protects against rust and corrosion while drying colourless and with no residue. It improves electrical conductivity, cleans, and removes aluminium corrosion. Again, I sprayed some into a cup and used Q-Tips. I still had to scrape a little to remove the goo from the notch in the plastic surround, but it was easy to remove the glue, and the residue from the battery stickum came off pretty easy by spraying the cleaner on a paper towel and leaving it on the glue for about 15 minutes. Now it looks like new.
这个答案有帮助吗?
得分 0
添加一条评论
Ronson Lighter Fluid is the best solvent for pressure sensitive adhesives.
Totally non-destructive! I use it to remove candle wax dripped on the finest antique furniture.
Cleans mechanical watch movements.
give it time to soften adhesive then wipe with cloth or Q-Tip.
Can't recommend it enough!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 70
总计 26,160
