跳转到主内容
加入维修社区 - 创建账户
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
Computer not turning on
I tried repairing my screen myself. It seemed like I did everything fine but when I got to the part where I put back the battery flex cable, I realized that i did not unwatchable it before pulling it out. The computer is not charging or turning on (rightfully so). Could this cable cause this to happen? Will replacing it help or have i messed up the connector?
I attached a vouple of pictures. Theyre they best i could do. Nothing looks damaged to my eyes but...
Update (08/17/25)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It's not that uncommon what the cable gets damaged the system won't start. It's also possible the ZIF connector compression latch is not correctly set. Can you post a nice clear pictures of the connectors (both sides) so we can see them and the cable as tight as you can (may need to add a bit of light).
If you want to get the cable ordered if it looks ratty or damaged here's the needed part BMU Flex Cable from TheBookYard in the UK
这个答案有帮助吗?
得分 1
2条评论:
I couldn't figure out how to add pictures here but I have attached it in the comment
完成的
@ophevan - The cable looks a bit rough, but one of the latches looks like it’s not fully clipped (lopsided) see if can reseat it.
完成的
添加一条评论
添加你的答案
Ophelia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 57
