跳转到主内容
May 2019 mfg date Model no.XL2540-B 244hz 1ms Gaming monitor
Double image on Zowie 240Hz
Hi im having a double image problem on my zowie monitor, ive tried changing the cables and its not from the gpu other monitors work fine even w the same cables used on the zowie, cant send it to warranty cause it was from a freind and its already past it as well, the only videos i can find of fixes are from people cutting out the connections on the monitors pcb, would like to know if anyone has had thsis problem before if they had found a solution that doesnt require blocking the conections on the pcb.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello man i have the same issue with mine
https://www.reddit.com/r/Zowie/comments/...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manuel Nunes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 94
