跳转到主内容
适用于 HP EliteBook 840 G7 的维修指南、拆解说明和故障排除信息。这款基于 Intel 平台的商务笔记本由惠普于 2020 年 5 月发布。
Wifi button is bot showing up in control center..
I don't have internet on my laptop, the wifi button just disappeared on control center
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This could mean a couple things, but usually the WiFi being gone altogether is indicative of a hardware failure. Or the WiFi service is disabled.
Assuming you're running Windows, I would right click on your Start menu and select Device Manager in. the list. Within that you should be able to see if there are any issues with any Network devices. If there is an error it will usually be obvious when you open the menu.
Check and see if your WiFi card is even present in the network devices. it would usually be listed specifically mentioning WiFi or mention specific wifi standards (n, ac, or other).
If it's not present, likely you'll need a new Wifi card. You can replace the internal one, but they make lots of USB WiFi adapters as well.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lava Lava 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 46
