跳转到主内容
PowerA Enhanced Wired Controller (Xbox) features a headset dial, a detachable 10ft USB cable, and mappable buttons.
Can I fix the left joystick click in not activating?
When I go to click in on the left joystick, it will not activate (usually to sprint in most games). Everything else seems to be working, and I've even changed out the joysticks. Not sure if this would need a flatout motherboard replacement, or if something else could potentially be done. Any help appreciated. ^+^
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you cleaned the connecting points? Sometimes contact cleaning spray can do a hell of a job when you experience missing controller signals. You changed the joystick and it still doesn´t work which means there must be a connction problem with for example the cupper lines or it´s less likely a weird software bug which you may fix with a reset.
这个答案有帮助吗?
得分 0
2条评论:
@Cafugo I did break it down at one point and everything seemed (to my untrained eye) to be fine, but i did use some isopropyl just to clean around the contacts (not sure if that was the right stuff to use). As far as a potential software bug, how would I go about resetting it?
完成的
I´m not familiar with the exact modell, but there could be a small hole an the backsite which usually works as a reset button.
完成的
添加一条评论
添加你的答案
CHAOTIC426 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 92
