跳转到主内容
加入维修社区 - 创建账户
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
How to replace/fix home button?
After falling on the floor (1 meter high drop), my 8GB iPhone operates properly except for the home button which does not work anymore. I can "click" with it but it has no effect. The USB connector works well as i can recharge the iPhone without any problem.
i have not found any tutorial/guide for changing a broken home button, or any connector that may be connected to it.
On your photos, i have not seen the Home Button... :-(((
Any ideas, or should I try to sell it for parts?
many thanks for your feedback,
Best Regards
Jean-Baptiste
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
No need to get rid of the iPhone due to "Home" button malfunction. Search Google for "iPhone home button repair" you will find the part(s) you need. Make sure you get the correct button (2g, 3g, 3gs).
Update
No need to vote down. I didn't post links because I wasn't sure if it was allowed. You didn't say if you had a 3G or 3Gs, I will assume you have a 3G. Easiest way to change the home button and circuit is to get a complete top (digitizer, glass, home button, etc). Just use ifixit's tear down guide to disassemble and reassemble.
Here is a Ebay link to the unit: http://tinyurl.com/yzhnfe5
It may not be the cheapest solution ($67.99 USD), but it will be the easiest.
*Please vote up if I've helped
这个答案有帮助吗?
得分 4
1条评论:
That's not real helpful- can you link to a button and a guide?
完成的
添加一条评论
添加你的答案
JeanBaptiste 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 21,470
