跳转到主内容
A portable WiFi hotspot, also known as a mobile hotspot, is a device that allows you to connect to the internet wirelessly from anywhere, as long as you have cellular coverage.
How to open the casing on this hotspot?
Hi, ive had a bunch of ants nest in this Telstra 5G hotspot twice now. The first time a couple months ago, had no issues and no ants since and they randomly showed up again today.
Just wanting to know how to pry open the casing to get in there and get the rest of the ants out as shaking and whacking them out of the USB ports isn’t getting them all out. I can’t seem to find any kind of button or lever that could quickly pop it open, and have tried using a credit card, knife and my fingernails but just can’t get it open.
It’s an MU5120 model.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @maltie
You may have to apply some heat (hair dryer?) around the edges of the rear cover to see if it softens the adhesive sufficiently to be able to insert an appropriate pry tool (examples only) to remove the cover.
Do not get it too hot as you don't want to cause problems with the battery becoming overheated
Also check that there's no recessed screw under the product label that may be holding it in place as well, just in case
Assorted prying tools for all types of enclosure opening, cable unhooking, digitizer removal and more. A complete set of opening tools all in one kit, perfect for electronic repairs. For professionals and beginners alike.图片
产品
Prying and Opening Tool Assortment
$9.95
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
maltie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 42
