跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
iPhone 3G gets down when not connected
iPhone 3G was working fine on iOS 4.2.1
suddenly, due to some reason, its getting crashed/not working with just a blank screen.... no hard reset !!
and then if plugged in charger or USB, Apple icon comes in and after few minutes, its working absolutely fine till its connected either to charger/USB.
Initially, i wondered whether its battery problem, but... once iPhone is in on state... battery percentage is Max.
I tried restoring it but no effect on my issue.
please advice...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
If only works with power connected, USB charger or computer. I would try a new battery.
这个答案有帮助吗?
得分 1
添加一条评论
I would try to replace the battery and the dock connector. It also could be a short in the phone. I had a similar issue on an iPhone 4. When I took the phone apart and disconnected the battery and the charging dock and plugged it back together it worked fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sameer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 377
