跳转到主内容
The GeForce GT 1030 was an entry-level graphics card by NVIDIA, launched on May 17th, 2017. Built on the 14 nm process, and based on the GP108 graphics processor, in its GP108-300-A1 variant, the card supports DirectX 12.
Display not output by graphic card
I plug my graphic card in slot when I plug display output cable ( hdmi ) but I screen the no device connected shows even I change my cable also
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you have a second monitor or system to verify if the display is working or even try a second system to make sure the video slot is not damaged. If the card is still not sending a video signal then you've isolated the issue to the card and will need to dig into the cards logic, that will require component level diagnostics.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Apurva 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 126
