跳转到主内容
Released 2006, identified by model number E1705
Asking for administrator password
When I power on the laptop it asks for an administrator password. Can someone advise how to do that
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You can reset the password using the following steps:
Accessing the BIOS and Resetting the Password:
  1. Enter the BIOS: Turn on or restart the computer and press F2 repeatedly during the Dell logo screen to enter the System Setup (BIOS).
  2. Navigate to Security: In the BIOS settings, locate the "Security" section.
  3. Reset the Password: If a password is set, you might be able to reset it by deleting the existing password or by using a recovery option, if available. If you have a password reset disk of diskless option, you can use it to clear the BIOS password.  Password resets on some Dell models might require your Dell computer's serial number.
  4. Save Changes: If you've made any changes, be sure to save them before exiting the BIOS.
The default administrator account username for Dell computers is usually "Admin" or "dellsupport" according to Dell.
If all else fails, you might need to perform a factory reset, which will erase your data and restore the computer to its original settings.
If you need the data from the machine, you can read all of the drive's files by plugging it into another PC via SATA or a powered USB to SATA adapter.
Hope this helps you out!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Travis Edwards 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 43
