跳转到主内容
Repair guides, disassembly, and troubleshooting information for the fifth generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-050.
How do I replace the L2 and R2 buttons?
The L2 and R2 seem to be different from earlier versions of the controller. I don’t see the pins that are described in prior versions, so am having difficulty removing them.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Jason, the L2 and R2 triggers on the Dual Sense guides can be found here:
Ifixit button guide - Follow this guide until step 26
then reference this YouTube video of L2 and R2 replacement and cleaning instructions
Notes about this fix:
The L2 and R2 triggers contact the membrane located on the black plastic mid-frame assembly, similarly to all the face buttons
If cleaning (ifixit carries this cleaning kit) the membrane does not resolve your issue, the replacement part can be found here from Mobile Sentrix.
For future reference, the dual-sense edge controller uses Hall effect triggers, which never fail before the rest of the controller.
I hope you find this helpful, and feel free to reach out with any questions or issues you encounter.
Regular cleaning of your devices is one of the best practices of preventative maintenance to enhance their lifespan. iFixit has assembled a group of helpful and practical tools to tackle cleaning hard-to-reach areas.图片
产品
Precision Cleaning Kit
$14.95
这个答案有帮助吗?
得分 0
4条评论:
Thank you. I figured it out and found there is a gear with rod that secures the L2 button down. My son managed to shear the rod off. Now to find a replacement piece.
完成的
Thank you. It’s for a BDM-050 so those parts aren’t compatible. I’m sure I’ll be able to find them though. Looks like I’m only finding them if purchased with the entire mid-frame though.
完成的
@jasoncornell best of luck if all else fails, your local repair shop might have parts from an otherwise unreapirable controller :)
完成的
添加一条评论
添加你的答案
Jason C. 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 62
过去 30 天: 318
总计 1,061
