跳转到主内容
加入维修社区 - 创建账户
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
Key only works without keycap on
I have been changing the keys on this Macbook due to language layout, and one of the keys only seem to work when taping lightly on the rubber dud, and not with the key installed.
Update (07/15/25)
Link to video: https://www.dropbox.com/scl/fi/jubtreen3...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have encountered this in the exact same scenario on a 2012 MBP model, switching from Arabic to ABC keys (The option key in my case was not working). I managed to solve it by removing the rubber dud, then re positioning it slightly and then clipping back the key cap. It worked after a couple of attempts. I cannot confirm it worked for the long haul as the unit went back to the owner, they haven't said it has stopped working after 6 months or so..... maybe worth a try if any other methods failed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sonnicham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 130
